Home > Forums > Software User Forums > SU2
How are gradients updated on ghost points?
Old   November 6, 2024, 04:28
Default How are gradients updated on ghost points?
AN
KleinMoretti is on a distinguished road
I didn't find the code about gradients updating on ghost points. In the CNEMOEulerSolver, there is the object "node_infty", which is defined by the following statement.
node_infty = new CNEMOEulerVariable(Pressure_Inf, MassFrac_Inf, Mvec_Inf,
Temperature_Inf, Temperature_ve_Inf,
1, nDim, nVar, nPrimVar, nPrimVarGrad,
config, FluidModel);
node_infty->SetPrimVar(0, FluidModel);
It just seems to specify the primitive variables information on node_infty. The gradient information seems to be set by the default value 0.
Under the path \SU2_CFD\include\gradients\..., I found the files that update the gradients, but they don't update the gradients on ghost points.
I would be very grateful if anyone could answer this for me!
KleinMoretti is offline   Reply With Quote
Old   November 19, 2024, 04:18
bigfoot
bigfootedrockmidget is on a distinguished road
Why do you need gradients on ghost points? The ghost points are introduced so you can compute gradients on boundary nodes. To compute boundary gradients, the halo nodes only need to contain values, not gradients.
bigfootedrockmidget is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Reflected ghost values of a solid boundary quarkz Main CFD Forum 1 July 25, 2007 07:33
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
Can you help me about ghost points? yujun Main CFD Forum 1 May 21, 2004 04:21
