Home > Forums > Software User Forums > SU2
waning messages during computation - suppression possible?
Like Tree4Likes
  • 3 Post By joshkellyjak
  • 1 Post By bigfootedrockmidget
Old   November 13, 2024, 10:18
Default waning messages during computation - suppression possible?
Giovanni Bettega
gbettega is on a distinguished road
Hello forum,
is there the possibility to suppress this kind of message
Warning: y+ < 5 in 117 points, for which the wall model is not active.
Warning: Computation of wall coefficients (y+) did not converge in 1 points.
using a proper setting in the .cfg file?
Thank you very much
Giovanni
gbettega is offline   Reply With Quote
Old   November 13, 2024, 10:28
Josh Kelly
joshkellyjak is on a distinguished road
Yes, set COMM_LEVEL= MINIMAL, this will supress the wall function output. It may also suppress other useful information so be careful.
joshkellyjak is offline   Reply With Quote
Old   November 14, 2024, 01:37
Giovanni Bettega
Thank you. It works. World record in fast answer discipline. Buona giornata
Old   January 6, 2025, 16:44
Post
Marcus021 is on a distinguished road
Hello, I'm piggybacking off this because I noticed that when setting COMM_LEVEL = MINIMAL and using mpirun the evolution of the residuals and the entire flow changes. This does not happen when using directly SU2_CFD.
In my case I was using wall functions and FGMRES was consistently failing orthogonalization after 200 or so iterations, while by enabling this option my simulation continues further with seemingly no hassle.
I have also tested this behaviour in a slightly modified version of the RAE2822 test case, where by suppressing warnings the simulation converges much faster.
I'm wondering if this behaviour is intended since perhaps this affects the way parallel computation operates or if there's something else going on that I'm missing? My cfg files were exactly the same aside from this option being present or absent. Thank you very much for anybody that's willing to shed some light on this.
Marcus021 is offline   Reply With Quote
Old   January 7, 2025, 01:57
bigfoot
bigfootedrockmidget is on a distinguished road
Sounds like we switch off too many things when COMM_LEVEL is not FULL. Can you create a ticket on github? If you can reproduce this with one of the standard testcases that we have, it will be easier to reproduce this.
https://github.com/su2code/SU2/issues
bigfootedrockmidget is offline   Reply With Quote
Old   January 7, 2025, 10:13
Post
Thank you for the reply, I have created the ticket, hopefully the info I have provided is enough to reproduce the issue and look into this.
I was wondering if I could follow up with another odd behaviour I noticed when using wall functions, I am not sure if this is a bug or if it is something caused by a fault of my own. Shall I make a new post on the forum or is it ok to write here?
Old   January 7, 2025, 11:04
bigfoot
if the issue is unrelated to the warning messages, it is better to create a new issue
Marcus021 likes this.
solver messages
PhD thesis with funding - Modelling of Fire Suppression in Heritage Buildings AxelCable CFD Freelancers 1 June 30, 2020 14:05
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 10:26
Discussion on the computation of the multi-stage axial compressor BalanceChen CFX 5 January 5, 2011 02:23
Cell face values computation un unstructured grids Sergio Rossi Main CFD Forum 2 May 28, 2006 10:04
