Jimin.Zhang
Rep Power: 3 ![]() |
Hello everyone!
When compiling in VSCode on Ubuntu, I noticed that sometimes when I specify the number of threads, some threads is not assigned any tasks. The specific issue is as follows: I used a total of three cases.In the first case, the grid size is very small, and when I specify more than 4 threads, one of the threads will not be assigned any tasks. In the second case, the grid size is medium, and when I specify more than 5 threads, it results in an error. In the third case, the grid size is large, and when I specify the maximum number of CPU cores, the computation runs normally. These issues occur when performing multi-zone computations. I'm looking forward to your reply. |
Evert Bunschoten
Rep Power: 2 ![]() |
Could you give some more details regarding your set-up? What do you mean by "small", "medium", and "large" grid sizes? What kind of multi-zone computations are you running?
Jimin.Zhang
Thank you!The terms "small," "medium," and "large" grids were intended to refer to the grid sizes in my test cases. However, I have already found the root cause of the issue. Thank you for your response!
Display Modes | |
MPI problem when using snappyHexMesh | Mohamed Mousa | OpenFOAM Running, Solving & CFD | 3 | September 17, 2017 11:45 |
MPI problem with fluent | daviyu | FLUENT | 0 | July 8, 2017 04:22 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
MPI problem with fluent | alexsatan | FLUENT | 2 | July 9, 2013 04:56 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
