aerolrion
Rep Power: 2 ![]() |
I am working on a project about launch pads. I wanna make CFD analysis with the help of SU2. In my project, I want to analyze flow which starts from nozzle exit by not analyzing nozzle's inside as you can see in the image. How can I make it on SU2?
bigfoot
Rep Power: 21 ![]() |
You did not give a lot of details so it's difficult to say. Do you already have the mesh and do you already know the boundary conditions? What are they? Is this a steady flow? I would start with the inviscid wedge tutorial and replace that setup with your mesh. Let us know how that works out!
aerolrion
I have a mesh that resolves a nozzle to achieve the shock diamonds in the picture. The flow is unsteady. There are not much data given in the reference paper so what we do is try to validate our inputs by trial and error. Solving inside the nozzle takes more time and since we don't know the exact parameters it's difficult to obtain exact results. If I can select an exit Mach or something like that to obtain a similar solution of the aforementioned picture that would be a great help.
Thank you for your time and answer. |
bigfoot
Well, what comes out of the nozzle is already an interacting shockwave pattern, so either you need to give a boundary condition at the nozzle exit that reproduces that exactly, or you need to take into account the interior of the nozzle.
You could try to create an inlet profile for it, or simply have an open interior and place the inlet inside the nozzle. |
aerolrion
I don't want to solve the nozzle inside, what boundary conditions can I get for this at the exit?
bigfoot
you could try
SPECIFIED_INLET_PROFILE = YES INLET_FILENAME = inlet.dat and the first time that you run it, it will give you a default inlet profile file that you can edit yourself. Actually, I am not sure if it works for supersonic inlets, I did not see an example testcase for it. So just give it a try. |
Evert Bunschoten
Regarding the outlet, you can just set a static pressure outlet with the static pressure at ambient.
aerolrion
Thank you for your responses, I'll try these.
Display Modes | |
Propeller calculation | toil | CFX | 19 | July 2, 2025 06:04 |
Transfer output data as input for second calculation | mannobot | Main CFD Forum | 3 | December 7, 2018 09:37 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
Heat Flux Calculation under REPORTS | Alberto Schroth | FLUENT | 0 | May 16, 2000 08:19 |
