Home > Forums > Software User Forums > SU2
RMS_dissipation (SST model) not seen?
Old   December 17, 2024, 02:22
Default RMS_dissipation (SST model) not seen?
Giovanni Bettega
gbettega is on a distinguished road
Hello forum,
I would like to activate convergence criterion for all the list of RMSs below,
for a certain convergence level: here -7.
% Convergence parameters
CONV_RESIDUAL_MINVAL= -7
CONV_FIELD= RMS_PRESSURE, RMS_VELOCITY-X, RMS_VELOCITY-Y, RMS_VELOCITY-Z, RMS_ENERGY, RMS_TKE, RMS_DISSIPATION
INNER_ITER= 1500
CONV_STARTITER= 10
After N<1500 iterations SU2 exists, and tells me:
| Convergence Field | Value | Criterion | Converged |
| rms[P]| -7.45293| < -7| Yes|
| rms[U]| -7.4718| < -7| Yes|
| rms[V]| -7.96358| < -7| Yes|
| rms[W]| -8.04231| < -7| Yes|
| rms[k]| -9.53798| < -7| Yes|
| rms[w]| -6.66409| < -7| No|
Indeed, as shown in picture, the rms[w] is not satisfied.
Question: is there a reason for that?
Thank you
Regards
Giovanni
gbettega is offline   Reply With Quote
Old   December 17, 2024, 13:22
bigfoot
bigfootedrockmidget is on a distinguished road
The solver will stop when INNER_ITER has been reached, regardless of the convergence criteria. If you set it INNER_ITER=3000, it will probably stop before, due to the convergence criteria.
bigfootedrockmidget is offline   Reply With Quote
Old   December 17, 2024, 14:56
Giovanni Bettega
Thanks you Big
That's Indeed the question. I put N=1500, and RMS limit -10. Solver did not reach N, but stops, with all the RMS residuals at <-10, apart fron RMS of dissipation, which Is only close tò -10, but greater.
I'll check
Thanks you
Giovanni
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 18:10
Boundary condition for k-omega SST model with high/low Re jiadongw OpenFOAM Running, Solving & CFD 5 November 15, 2021 10:40
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 05:36
Application of SST model by CEL linlin.geng CFX 10 October 29, 2017 15:30
Backward facing ramp - SST k-omega model y+ requirements Crank-Shaft Main CFD Forum 0 May 2, 2013 06:07
