Home > Forums > Software User Forums > SU2
NACA RANS simulation
Old   December 30, 2024, 11:32
Default NACA RANS simulation
Gaurav Gupta
airwarriorg91 is on a distinguished road
Hello Everyone !
I am new to SU2 for CFD simulations. I trying RANS simulation for NACA 64(1)-412 airfoil at Re=20000. I have conducted DNS simulation using NEK5000 for the same case and obtained satisfactory results.
The domain is 30c x 12c with airfoil centered at (10c,0). It has velocity inlet with (1,0,0) and pressure outlet (P=0). The top and bottom wall are periodic whereas the airfoil is wall is no-slip and adiabatic wall. The case is non-dimensionalized such that the Re=20000. The mesh is such that y^+<1.
I used the numerical settings from the turbulent NACA 0012 tutorial case.
The problem is flow converges and looks correct. But the lift coefficient is very off from the expected value whereas the drag coefficient is closer to the actual value.
| Case | CD | CL |
| Experiment | 0.036663 | -0.03036 |
| DNS | 0.03518 | -0.03245 |
| RANS | 0.03253 | 0.13866 |
I have attached the config file and mesh file for your reference. I am getting similar results using both SA and SST models. Can anyone help me in this ?
Thanks,
Gaurav
Files Link: https://drive.google.com/file/d/1D_V...ew?usp=sharing
airwarriorg91 is offline   Reply With Quote
Old   December 30, 2024, 17:52
bigfoot
bigfootedrockmidget is on a distinguished road
First thing that comes to mind is that the values used to nondimensionalize CL do not correspond, but then CD would probably also not be correct.
Then there is the issue of the mesh quality. If you look here:
https://turbmodels.larc.nasa.gov/naca0012_val.html
The meshes used for the final CL/CD curve are quite fine, also the far-field boundaries are quite far away. I would also change the periodic boundaries to far-field boundaries.
I had a quick look at your mesh and it is better to use a completely structured mesh like on the nasa website. It is easy to make with gmsh.
bigfootedrockmidget is offline   Reply With Quote
Old   January 1, 2025, 01:46
Gaurav Gupta
Hey !
Happy New Year !!
Non-dimensionalization is not an issue because I am getting the correct Re output in the SU2 screen output.
I am using a hybrid domain instead of the a structured domain since this is a validation case for the actual simulation (which has a complex geometry), hence structured grid is not possible in that case.
Also, I am trying to use the same mesh type and b.c. from DNS but the RANS mesh is 3x times the DNS mesh. I will try with a larger mesh. Although the current mesh is fine enough with y+<1. Is there some issue with periodic boundary conditions in SU2 (in comparison with farfield) ?
Thanks,
Gaurav
Old   January 3, 2025, 10:51
Gaurav Gupta
Hey @bigfoot !
I solved the issue by setting the turbulence_intensity and mach number to the experimental value. I didn't had to set these during DNS so I didn't notice these parameters. Now, I am getting the almost accurate values with the coarse (original) mesh itself.
Old   January 3, 2025, 12:13
bigfoot
Happy new Year!
That's great to hear that results are closer to measurements/DNS.
If you want, we can add your case to the validation test cases on the website. We can then also document that the results are quite sensitive to the turbulent boundary conditions.
Old   January 3, 2025, 13:50
Gaurav Gupta
Hey @bigfoot !
Sure, I am okay with the addition of the validation test cases on the website.
Right now, I was working on grid convergence. The initial mesh was coarse (66k elements), the current mesh comparatively fine (180k elements). Absurdly, the CL for fine mesh is converging to -0.08. I tried lower CFL values (25, 10, 7.5) but the no change. Do you know why this could happen ?
I have attached the updated cfg and mesh file along with the history file.
Link: https://drive.google.com/drive/folde...v_?usp=sharing
Old   January 3, 2025, 18:37
bigfoot
The history file shows that the case has not converged yet. The residuals, especially pressure, should converge to -12 at least (the convergence event horizon). It looks like your case is still converging, but much slower (as is often observed for larger meshes and finer cells).
So the first thing to do is to let it converge.
Then: CL is not guaranteed to converge monotonously with increasing mesh size. Some of the cell refinement will not impact your results. It might be that you need an even finer mesh.
And finally: RANS might simply not be super accurate - you could check in the literature on RANS results for this testcase. Although, for a NACA profile at zero angle of attack I expect decent results.
Old   January 4, 2025, 01:36
Gaurav Gupta
The case actually stalls at about -7 to -8 depending on the CFL number (See the attached image). For coarser mesh, the case converged to -14 at CFL of 25. Since it is zero AoA, I am also expecting some good results with RANS.
So, what should I do to improve the convergence and in regards to grid convergence ?
Last edited by airwarriorg91; January 4, 2025 at 02:58. Reason: Attached the residual plot
naca 64 airfoils, rans, su2
How can get Q criterion in RANS simulation R786 Main CFD Forum 4 February 19, 2023 05:24
3D Airfoil is not converging during RANS simulation Stian Hjorteland OpenFOAM Running, Solving & CFD 1 January 28, 2020 17:44
NACA Airfoil simulation giving different lift coefficients in 2D vs 3D mrlam FLUENT 8 May 16, 2019 18:17
Transient RANS Simulation Bazinga Main CFD Forum 5 June 21, 2017 11:21
Acoustic prediction from Rans simulation MachZero Main CFD Forum 0 May 1, 2017 07:07
