Home > Forums > Software User Forums > SU2
non-physical points
Old   December 30, 2024, 20:58
Question non-physical points
李以乐
lqliang1222 is on a distinguished road
hello everyone,
When I run SU2-NEMO related cases, a warning line will appear on the screen, similar to "Warning. The initial solution contains 100 points that are not physical", and as the number of iterations increases, the non physical points will gradually increase. May I ask what caused this issue and how to handle it? Thank you.
lqliang1222 is offline   Reply With Quote
Old   December 31, 2024, 07:13
bigfoot
bigfootedrockmidget is on a distinguished road
The solver might be slowly slowly diverging. Sometimes, the nr of unphysical points stabilizes and reduces again until the problem disappears altogether. You might be able to prevent it by using:
- better initial conditions
- different numerical settings, especially lower CFL or timestep values, or switching to a more diffusive numerical scheme
You can visualize the problem in paraview, see where it occurs and maybe you can think about a solution. Sometimes you see that it is a small region in the flow that is slowly being transported with the flow towards the outlet, then the problem will solve itself. This is what we observe often in the incompressible combustion model (flamelet model).
bigfootedrockmidget is offline   Reply With Quote
nemo, non-physical points
Sample utility bug? For many cloud points in the sampleDict, some are neglected! brandius OpenFOAM Post-Processing 10 August 22, 2022 09:56
[Gmsh] Cannot transfer physical surfaces to patches inside the boundary file celestial OpenFOAM Meshing & Mesh Conversion 3 November 25, 2019 15:58
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 15:25
