Home > Forums > Software User Forums > SU2
What is the class type of solver_container for IncNSSolver
Like Tree3Likes
  • 1 Post By bigfootedrockmidget
  • 1 Post By EvertBunschoten
Old   January 2, 2025, 02:43
Default What is the class type of solver_container for IncNSSolver
Qi Wang
QiWang is on a distinguished road
If I use IncNavier_Stokes in the configuration file, what exactly is the type of solver_container?
It is initialized in the CBaseSolver to be CSolver****, but it should be updated to be one of the derived classes right? I have been looking for the container_initialize but haven't find any clue.
Ultimately, I'm trying to find what SetInitialCondition the solver uses exactly. It has been three days and I just could not get this piece of information from the code.
QiWang is offline   Reply With Quote
Old   January 2, 2025, 04:08
bigfoot
bigfootedrockmidget is on a distinguished road
You can for instance follow one of the variables needed for initialization of the incompressible solver in vscode.
Take for instance INC_VELOCITY_INIT
You will see if you search for this variable, that there is a function GetIncVelocity_Init
This function is used in only one other file: CIncEulerSolver.cpp.
As you will see, the Navier-Stokes solver inherits a lot from the Euler Solver.
In the file, you will find CIncEulerSolver::SetNondimensionalization
If you do not use nondimensional numbers, the values used for nondimensionalization will simply be set to 1.
Another important place to look is CDriver.cpp, where the initialization has for instance InitializeSolver()
From this function, we call the initialization using the restart file.
QiWang likes this.
bigfootedrockmidget is offline   Reply With Quote
Old   January 2, 2025, 04:32
bigfoot
btw, if you want to do some special initialization, you can use the python wrapper for this. There are some examples in the TestCases folder.
QiWang likes this.
Old   January 2, 2025, 05:59
Qi Wang
Thanks for the reply! I did find the function in CIncEurlerSolver. However, I couldn't find where exactly that solver_container is set to be an instance of CIncEulerSolver. There is also some other initial condition in FVMSolver, which is really confusing because I really don't know exactly which one this sentence is calling
solver_container[ZONE_0][INST_0][MESH_0][FLOW_SOL]->SetInitialCondition(geometry_container[ZONE_0][INST_0], solver_container[ZONE_0][INST_0], config_container[ZONE_0], TimeIter);
Old   January 2, 2025, 06:05
Qi Wang
Thanks a lot for this heads-up. Yes I'm trying to do some special initialization for my adjoint calculation and reading the code from scratch is a big pain so far... I would really appreciate it if you could pinpoint one of the testcases so I can modify the initial condition for the adjoint calculation.
Old   January 2, 2025, 10:42
Evert Bunschoten
EvertBunschoten is on a distinguished road
The line
always calls the SetInitialCondition method from the derived class if defined. In case the solver you are using does not have the method SetInitialCondition defined, it will use the method from CFVMFlowSolverBase.
QiWang likes this.
EvertBunschoten is offline   Reply With Quote
su2
convergence problem of steady 2D film cooling calculation using chtMultiRegionFoam ruanyg968tf OpenFOAM Running, Solving & CFD 1 April 10, 2024 02:23
rhoSimpleFoam vs rhoPimpleFoam, steady state vs transient solver Oliver Meng OpenFOAM Running, Solving & CFD 28 January 12, 2023 04:13
activeBaffleVelocity boundary condition ? om3ro OpenFOAM Programming & Development 10 November 16, 2020 23:26
rSF: p divergence in combustor (wt negative value) zonda OpenFOAM Pre-Processing 4 April 10, 2018 06:59
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 17:18
