Home > Forums > Software User Forums > SU2
air_7 in Mutationpp
Like Tree1Likes
  • 1 Post By CleverBoy
Old   January 5, 2025, 21:15
Post air_7 in Mutationpp
hamburger is on a distinguished road
I'm trying to calculate the 7-species hypersonic cases using mutationpp and SU2 8.10 and I'm having some problems. I noticed that there is no documentation that gives the order of the components of the 7-species reaction in the mutation library, and whether or not it's the same as in SU2_NONEQ. In addition to this is the order of the components in INLET_GAS_COMPOSITION affected by the different FLUID_MODELs?
hamburger is offline   Reply With Quote
Old   January 7, 2025, 03:53
Ercan Umut
CleverBoy is on a distinguished road
I did not use air-7 before but for air-5 the order of components are different between M++ and SU2_NONEQ. In M++ it is (N,O,NO,N2,O2) and for the native library its the other way around. This probably holds for air-7 as well. Also mind that in M++ gas model is defined as "air_5". I guess you can check M++ documentation for detailed information.
giovanni.medici likes this.
CleverBoy is offline   Reply With Quote
Old   January 7, 2025, 04:38
Smile reply to CleverBoy
Thanks for your answer. I noticed the difference between the two FLUID_MODELs in the air-5 model, but unfortunately I still haven't found the exact order of the air-7 in mpp.
In addition to this, I would like to know as well as when using the MARKER_SUPERSONIC_INLET, does the order of the component of the INLET_GAS_COMPOSITION change as the FLUID_MODEL is changed?
Thanks again for your answers!
NEMO shock tube with MUTATIONPP Athos_e SU2 6 April 26, 2024 07:07
