Giovanni Bettega
Rep Power: 12 ![]() |
Hello forum.
a steady state, incopressible run. Su2 starts, and calculation goes on up to N iterations, or convergence, when I issue mpiexec.exe -n <x> SU2_CFD_MPI.exe Su2_20250101120547622.cfg when x = 1,2,3,4,5,7,8. But, for x = 6, i.e. mpiexec.exe -n 6 SU2_CFD_MPI.exe Su2_20250101120547622.cfg the solver stops, and the console output is: " [...] Setting the control volume structure. Volume of the computational grid: 0.122733. Searching for the closest normal neighbors to the surfaces. Storing a mapping from global to local point index. Compute the surface curvature. Error in "long int CGeometry::FindEdge(long unsigned int, long unsigned int, bool) const": ------------------------------------------------------------------------- Can't find the edge that connects 12522 and 12345. ------------------------------ Error Exit ------------------------------- job aborted: [ranks] message [0] application aborted aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 0 [1-5] terminated ---- error analysis ----- [0] on HELLO SU2_CFD_MPI.exe aborted the job. abort code 1 ---- error analysis ---- " I attach a link to the .cfg and mesh file. https://drive.google.com/file/d/1rjM...usp=drive_link Why? Grazie mille Giovanni |
Giovanni Bettega
For sure the fact that the solver stops depends on the number of cores, but in principle, at the very beginning, it seems to be due to the present one/two distorted elements in the mesh. I will check.
G |
mpi error |
Display Modes | |
Solver exits during transient solver run ERROR #001100279 | kostiable1 | CFX | 5 | July 31, 2022 19:25 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Run Mode:Platform MPI Local Parallel core problem | mztcu | CFX | 0 | October 13, 2016 03:14 |
Compiled library vs. inInclude Files, DSMC solver crashes after run | GPesch | OpenFOAM Programming & Development | 8 | April 18, 2013 07:17 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
