Home > Forums > Software User Forums > SU2
Steady rotation
Old   January 27, 2025, 02:55
Default Steady rotation
Moses
MSTEINBUCH is on a distinguished road
I tried to get the coefficient Clp - resistance to rolling. I used the cards
GRID_MOVEMENT= ROTATING_FRAME
MACH_MOTION=
MOTION_ORIGIN=
ROTATION_RATE=
Expected to get Clp by dividing the result CMX by ROTATION_RATE input but the result was far from expected
Please Help
MSTEINBUCH is offline   Reply With Quote
Old   January 29, 2025, 16:35
bigfoot
bigfootedrockmidget is on a distinguished road
Can you give the definition of the resistance to rolling?
CM is simply computed using all contributions of this form in all nodes:
CMx += (Force[2] * MomentDist[1] - Force[1] * MomentDist[2]) / RefLength;
with pressure forces given as:
Force[iDim] = -(Pressure - Pressure_Inf) * Normal[iDim] * factor * AxiFactor;
with factor being 1/(0.5 * Density_Inf * RefVel2 * config.GetRefArea())
So if the definition of Cl_p = CM / rotation-rate, even then it can be tricky to get the right value since you have to correctly set all the reference values.
bigfootedrockmidget is offline   Reply With Quote
Old   February 2, 2025, 02:47
Lightbulb rolling damping
Moses
Rolling dumping moment results from differences of angles of attack between right wing and left wing due to rotation. (Hope attached successfully the picture).
A section of the right wing located a distance y from the centerline will experience an increment in its angle of attack because of P, given by \Delta\alpha=Py/V
A rough estimation of the damping moment coefficient for simple tapered wing is given by Clp= -a0/12*(1+3\lambda)/(1+\lambda), where a0 is wing lift slope and lamda is (tip cord)/(root cord).
Wondering if use of normalized roll rate p*SPAN/(2VREF) instead of rad/sec for ROTATION_RATE will fix the problem
rotating_frame
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 07:03
Java Macro -- Passive Pith in Superposing Rotation Motion Weidong Dai STAR-CCM+ 2 August 4, 2018 05:39
UDF for 1DOF Rotation ram_call Fluent UDF and Scheme Programming 5 December 29, 2017 13:55
Can not achieve statistically steady flow in Openfoam jiaodanuma OpenFOAM 0 August 16, 2016 06:49
Simulating an unsteady phenomenon with a steady model JochemGrietens Main CFD Forum 2 April 13, 2016 11:51
