Dr Arsad Quraishi
Rep Power: 2 ![]() |
Hi
I wanna simulate argon ion transport with stationary neutral argon atoms in the background? Is it possible to simulate this in SU2? Could you please give me some guidance on this? The geometry will be simple rectangular duct/step |
bigfoot
Rep Power: 21 ![]() |
for hypersonic flows? Then use the NEMO framework.
Dr Arsad Quraishi
Thanks. It would be weakly compressible flows. Yeah I m trying to figure out NEMO but couldn't understand yet how to simulate argon ions dynamics with stationary neutral argon background. Any suggestions in this regard will be much appreciated!
#4 | |
Dr Arsad Quraishi
Hi Any suggestion on this please? |
Catarina Garbacz
Rep Power: 7 ![]() |
by "stationary neutral argon background" you mean neutral argon freestream that ionizes? Yes you can do this with NEMO. What exactly do you need to know? To use NEMO with mixtures different than air-5,air-7,N2 and neutral Argon, you need to use mutation++ which is coupled to SU2-NEMO. In the SU2/TestCases/nonequilibrium/viscwedge_mpp/ you have an example of a case using mutation++ In SU2/TestCases/nonequilibrium/visc_cylinder/ you have an example of ionization for air-7 without mutation++ Combining these two examples, you can set a case for ionization with mutation++. To have argon allowing for ionization, you need to create your own mixture and mechanism of reaction files, as per the examples given in mutationpp/data/mixtures and mutationpp/data/mechanisms These are initial guidelines but perhaps something to start with and feel free to ask more specific questions if you need help |
Dr Arsad Quraishi
Hi Catarina
Thank you so much for your guidance so far. It did help. Much appreciated! I ran the following cases suggested by you: SU2/TestCases/nonequilibrium/visc_cylinder/ using SU2_NEQ SU2/TestCases/nonequilibrium/viscwedge_mpp/ using MUTATIONPP Both the cases ran quite well. CASE-1 Then I took the viscous cylinder case (SU2/TestCases/nonequilibrium/visc_cylinder/) with flow conditions remaing the same and changed the gas mixture to N2,N2+,N,N+ and e- using mutationpp https://github.com/mutationpp/Mutati...input-files.md the mixture (N2_mix.xml) and mechanisms (N2_mix.xml) file are attached for reference. The only change to cfg file was: GAS_MODEL= N2_mix GAS_COMPOSITION= (0.99, 0.001, 0.001, 5e-13, 5e-13) TRANSPORT_COEFF_MODEL= WILKE CFL_NUMBER= 0.1 (tried 0.001) I get the following error: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ------------------------------ Begin Solver ----------------------------- Simulation Run using the Single-zone Driver Warning, didn't converge temperatures: f = 4.8595e+09 Warning, didn't converge temperatures: f = 4.8595e+09 Warning, didn't converge temperatures: f = 4.8595e+09 Warning, didn't converge temperatures: f = 4.8595e+09 Warning, didn't converge temperatures: f = 4.8595e+09 Warning, didn't converge temperatures: f = 4.8595e+09 Warning. The initial solution contains 33344 points that are not physical. Warning!! Instances of NaN in the following source terms: Axisymmetry: 4962 Chemical: 4962 Vib. Relax: 4962 Warning!! Instances of NaN in the following source terms: Axisymmetry: 5419 Chemical: 5419 Vib. Relax: 5419 Warning!! Instances of NaN in the following source terms: Axisymmetry: 5431 Chemical: 5431 Vib. Relax: 5431 Warning!! Instances of NaN in the following source terms: Axisymmetry: 5422 Chemical: 5422 Vib. Relax: 5422 Warning!! Instances of NaN in the following source terms: Axisymmetry: 5420 Chemical: 5420 Vib. Relax: 5420 Warning!! Instances of NaN in the following source terms: Axisymmetry: 5422 Chemical: 5422 Vib. Relax: 5422 Error in "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)": ------------------------------------------------------------------------- SU2 has diverged (NaN detected). ------------------------------ Error Exit ------------------------------- xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx CASE-2 e-, Ar+, Ar mixture for above vscous cylinder case. For now, I m running this for viscous cylinder case, but need to run for CD nozzle and eventually rectangular/step geometry. This is my target simulation actually. The simultions are runing for viscolus cylinder case,but the values printed on screen aren't changing much. Here is the snapshot after 10k iterations: | 9516| -16.835949| -5.173191| -4.650124| 2.702567| -2.336905| -0.008635| 0.000000| 7.0367e+04| | 9517| -16.846160| -5.183402| -4.660334| 2.691006| -2.333945| -0.008635| 0.000000| 7.0362e+04| | 9518| -16.843025| -5.180267| -4.657200| 2.694214| -2.330853| -0.008635| 0.000000| 7.0356e+04| | 9519| -16.842097| -5.179339| -4.656272| 2.695318| -2.320753| -0.008635| 0.000000| 7.0351e+04| | 9520| -16.839410| -5.176652| -4.653585| 2.698406| -2.323075| -0.008635| 0.000000| 7.0346e+04| | 9521| -16.843255| -5.180497| -4.657429| 2.694412| -2.340916| -0.008635| 0.000000| 7.0340e+04| | 9522| -16.845681| -5.182924| -4.659856| 2.691368| -2.342332| -0.008634| 0.000000| 7.0335e+04| | 9523| -16.850042| -5.187285| -4.664217| 2.686412| -2.332234| -0.008634| 0.000000| 7.0329e+04| | 9524| -16.837505| -5.174747| -4.651679| 2.700745| -2.317436| -0.008634| 0.000000| 7.0324e+04| | 9525| -16.837906| -5.175148| -4.652080| 2.700601| -2.303656| -0.008634| 0.000000| 7.0319e+04| | 9526| -16.833535| -5.170777| -4.647710| 2.705273| -2.300092| -0.008634| 0.000000| 7.0313e+04| | 9527| -16.831439| -5.168681| -4.645614| 2.707864| -2.288069| -0.008634| 0.000000| 7.0308e+04| | 9528| -16.831931| -5.169173| -4.646106| 2.707455| -2.286073| -0.008634| 0.000000| 7.0302e+04| | 9529| -16.827159| -5.164401| -4.641333| 2.712853| -2.288946| -0.008634| 0.000000| 7.0297e+04| | 9530| -16.823469| -5.160712| -4.637644| 2.716871| -2.266998| -0.008634| 0.000000| 7.0292e+04| | 9531| -16.833619| -5.170861| -4.647793| 2.704761| -2.287797| -0.008634| 0.000000| 7.0286e+04| | 9532| -16.837472| -5.174714| -4.651647| 2.700340| -2.310097| -0.008634| 0.000000| 7.0281e+04| | 9533| -16.840277| -5.177520| -4.654452| 2.697283| -2.317660| -0.008634| 0.000000| 7.0275e+04| FLUID_MODEL= MUTATIONPP GAS_MODEL= argon_ion GAS_COMPOSITION= (5E-13, 0.23, 0.767) TRANSPORT_COEFF_MODEL= WILKE CFL_NUMBER= 0.05 (it runs with 0.5 as well, but diverges aftre few thousands of iterations) I checked the intermediate files pritnted, the mass fraction of e-, Ar+ and Ar, seems to be constant throughout and not changing. Considering ionization, the mass fraction should change right? Do i need to switch on any other parameters ionization? I see some options in master cfg file [% % Specify if there is ionization IONIZATION= NO] Is there any mistake in mechanism/mixture file format,units etc?I still need to double check arhenius coeeficients as the order of magnitude looks slightly different I'm attaching both mixture/mechanism files here for CASE-1&2 Could you please help me on CASE-1 &2 |
Catarina Garbacz
Can you attach the 4 input files please:
.cfg .su2 mix file mechanism file |
#8 | |
Dr Arsad Quraishi
N2_mix.png N2_Mechanism.png |
#9 | |
Dr Arsad Quraishi
ArgonMix.png ArgonMechanism.png |
#10 | |
Dr Arsad Quraishi
.su2 mesh file is same as that on non-equlibrium viscous cylinder located here; https://github.com/su2code/TestCases.../visc_cylinder |
Display Modes | |
SU2 Optimization/ASO - Not Saving/Writing Files of Adjoint Simulations | rgbatista | SU2 Shape Design | 5 | February 1, 2024 18:50 |
Bruggeman Model vs Tortuosity Model in Ion Exchange Membranes | Omar_Elshawarby | COMSOL | 0 | May 11, 2023 03:10 |
Time-step size for coupled implicit simulations | pi120 | STAR-CCM+ | 3 | March 16, 2022 21:08 |
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations | maddalena | OpenFOAM | 2 | July 13, 2011 08:55 |
URANS and Transient Simulations | bob | Main CFD Forum | 0 | October 1, 2003 03:54 |
