Home > Forums > Software User Forums > SU2
Is that possible to mapping the mesh with predefined FFD control points in mesh file
Old   March 14, 2025, 01:38
Default Is that possible to mapping the mesh with predefined FFD control points in mesh file
Tongtong
Tongtong1919 is on a distinguished road
Hi everyone,
I would like to ask whether the current SU2 FFD (Free-Form Deformation) module supports mapping the mesh using predefined control points.
I came across a post from 2015 discussing a similar issue:
In some cases, especially when the geometry has high curvature, there can be significant gaps between the surface to be mapped and the FFD box defined by corner points and their linearly iterated control points. In such scenarios, objective functions or constraints may be insensitive to the coordinates of control points far from the surface. Optimizers might then make large changes to these coordinates, possibly resulting in strange surface deformations in test cases.
Has this issue been resolved in the current version of SU2, or are there alternative methods available to address it?
Tongtong1919 is offline   Reply With Quote
deformation, ffd, turbo-machinery
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
Is that possible to mapping the mesh with predefined FFD control points in mesh file? Xianguu SU2 Shape Design 1 May 19, 2015 16:47
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
