Gaurav Gupta
Rep Power: 2 ![]() |
I am trying RANS around a 3D sphere at RE=100000. The case is diverging. I tried lowering the CFL from 30 to 10 and increasing the linsol error from 1E-2 to 1E-4 but the case diverges. The mesh is a structured mesh created in Pointwise. The mesh quality parameters are as follows: 1. Cell Non-Orthogonality < 30 deg 2. Jacobian > 0 3. Minimum Included Angle > 59 deg and <90 deg I have attached the case files: https://github.com/airwarriorg91/SU2.../master/sphere The log files are also attached. Can someone help me with this ? Thanks Gaurav |
Josh Kelly
Rep Power: 8 ![]() |
I have found with Roe with MUSCL reconstruction is that in cases like this where it diverges soon after solver start is to run the simulation without the reconstruction until you achieve some level of convergence and then restart with the MUSCL reconstruction enabled normally resolves the issue. This might help for the case you have described.
Gaurav Gupta
Hi !
I am using L2ROE with MUSCL resconstruction in convective and scalar upwind with MUSCL in turbulent scheme. I tried turning off the MUSCL reconstruction but the cases still diverges. Do you know why this might be happening ? |
3drans, su2 |
Display Modes | |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
Running Multiple OpenFOAM Cases at Once on HPC | papamilad | Hardware | 5 | August 2, 2019 12:20 |
multiple -parallel cases on single node with single mpirun | mrishi | OpenFOAM Running, Solving & CFD | 1 | June 3, 2019 13:26 |
Test cases of AIAA Sonic Boom Prediction Workshop | prince155 | Main CFD Forum | 0 | September 13, 2018 12:45 |
Directory constructions of complex cases | 7islands | OpenFOAM | 2 | August 26, 2008 05:25 |
