Shock wave/boundary layer int at Mach 2.9 can not be simulated correctly by SA_EDDES |
shancongtao
Rep Power: 0 ![]() |
I am simulating the shock wave/boundary layer interaction (SBLI) using SU2.
Everything is ok using SA, while grid-induced separation is observed in the case simulated by SA_EDDES. I guess that in SA_EDDES attached boundary layer is simulated by LES rather than RANS. Who can give me a suggestion for the usage of SA_EDDES in SBLI at Mach 2.9, or how lengthScale = wallDistance-f_d*max(0.0,(wallDistance-distDES)) can be writed as output for me to figure out where are RANS and LES. SA_cfg.txt SA_EDDES_cfg.txt SA_DDES.jpg SA.jpeg |
boundary layer, ddes, shock wave, supersonic |
Display Modes | |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
Shock Wave/Boundary Layer Interactions (SWBLI) | rajeev | Main CFD Forum | 8 | June 1, 2001 12:20 |
