[Sponsors] | |||||
Taimour
Rep Power: 0 ![]() |
I am trying to run my own case for a simple cylinder
also I attached a picture at the end for showing the physical groups of INLET OUTLET WALLS AND CYLINDER now I am getting this error D:\Productividad\SU2\bin\CASES\C4>SU2_Mesh D:\Productividad\SU2\bin\CASES\C4\mesh_cylinder.su 2 'SU2_Mesh' is not recognized as an internal or external command, operable program or batch file. D:\Productividad\SU2\bin\CASES\C4>ren poly_cylinder.txt poly_cylinder.cfg D:\Productividad\SU2\bin\CASES\C4>SU2_CFD poly_cylinder.cfg ------------------------------------------------------------------------- | ___ _ _ ___ | | / __| | | |_ ) Release 8.1.0 "Harrier" | | \__ \ |_| |/ / | | |___/\___//___| Suite (Computational Fluid Dynamics Code) | | | ------------------------------------------------------------------------- | SU2 Project Website: https://su2code.github.io | | | | The SU2 Project is maintained by the SU2 Foundation | | (http://su2foundation.org) | ------------------------------------------------------------------------- | Copyright 2012-2024, SU2 Contributors | | | | SU2 is free software; you can redistribute it and/or | | modify it under the terms of the GNU Lesser General Public | | License as published by the Free Software Foundation; either | | version 2.1 of the License, or (at your option) any later version. | | | | SU2 is distributed in the hope that it will be useful, | | but WITHOUT ANY WARRANTY; without even the implied warranty of | | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU | | Lesser General Public License for more details. | | | | You should have received a copy of the GNU Lesser General Public | | License along with SU2. If not, see <http://www.gnu.org/licenses/>. | ------------------------------------------------------------------------- Parsing config file for zone 0 ----------------- Physical Case Definition ( Zone 0 ) ------------------- Incompressible Laminar Navier-Stokes' equations. No restart solution, use the values at infinity (freestream). Dimensional simulation. The reference area is 1 m^2. The semi-span will be computed using the max y(3D) value. The reference length is 1 m. Reference origin for moment evaluation is (0.25, 0, 0). Surface(s) where the force coefficients are evaluated: CYLINDER. Surface(s) plotted in the output file: CYLINDER. Input mesh file name: mesh_cylinder.su2 --------------- Space Numerical Integration ( Zone 0 ) ------------------ Flux difference splitting (FDS) upwind scheme for the flow inviscid terms. Second order integration in space, with slope limiter. No slope-limiting method. Average of gradients with correction (viscous flow terms). Gradient for upwind reconstruction: Green-Gauss. Gradient for viscous and source terms: Green-Gauss. --------------- Time Numerical Integration ( Zone 0 ) ------------------ Local time stepping (steady state simulation). Euler implicit method for the flow equations. FGMRES is used for solving the linear system. Using a ILU(0) preconditioning. Convergence criteria of the linear solver: 1e-15. Max number of linear iterations: 10. No CFL adaptation. Courant-Friedrichs-Lewy number: 1e+03 ------------------ Convergence Criteria ( Zone 0 ) --------------------- Maximum number of solver subiterations: 2000. Begin convergence monitoring at iteration 10. Residual minimum value: 1e-14. Cauchy series min. value: 1e-06. Number of Cauchy elements: 100. Begin windowed time average at iteration 0. -------------------- Output Information ( Zone 0 ) ---------------------- File writing frequency: +------------------------------------+ | File| Frequency| +------------------------------------+ | RESTART| 250| | PARAVIEW| 250| | SURFACE_PARAVIEW| 250| +------------------------------------+ Writing the convergence history file every 1 inner iterations. Writing the screen convergence history every 1 inner iterations. The tabular file format is CSV (.csv). Convergence history file name: history. Forces breakdown file name: forces_breakdown.dat. Surface file name: surface_flow. Volume file name: flow. Restart file name: restart_flow.dat. ------------- Config File Boundary Information ( Zone 0 ) --------------- +-----------------------------------------------------------------------+ | Marker Type| Marker Name| +-----------------------------------------------------------------------+ | Far-field| farfield| +-----------------------------------------------------------------------+ | Inlet boundary| INLET| +-----------------------------------------------------------------------+ | Outlet boundary| OUTLET| +-----------------------------------------------------------------------+ | Isothermal wall| CYLINDER| +-----------------------------------------------------------------------+ -------------------- Output Preprocessing ( Zone 0 ) -------------------- WARNING: SURFACE_PRESSURE_DROP can only be computed for at least 2 surfaces (outlet, inlet, ...) Screen output fields: INNER_ITER, RMS_PRESSURE, RMS_TEMPERATURE, LIFT, DRAG, TOTAL_HEATFLUX History output group(s): ITER, RMS_RES Convergence field(s): RMS_PRESSURE Warning: No (valid) fields chosen for time convergence monitoring. Time convergence monitoring inactive. Volume output fields: COORDINATES, SOLUTION, PRIMITIVE ------------------- Geometry Preprocessing ( Zone 0 ) ------------------- Two dimensional problem. 13072 grid points. 12836 volume elements. 4 surface markers. 52 boundary elements in index 0 (Marker = INLET_). Error in "short unsigned int CConfig::GetMarker_CfgFile_TagBound(const string&) const": ------------------------------------------------------------------------- The configuration file doesn't have any definition for marker INLET_ ------------------------------ Error Exit ------------------------------- job aborted: [ranks] message [0] application aborted aborting MPI_COMM_WORLD (comm=0x44000000), error 1, comm rank 0 PLEASE HELP, THANK YOU. Last edited by Taimour; April 6, 2025 at 12:25. Reason: Added another picture of error |
bigfoot
Rep Power: 23 ![]() |
There seems to be an extra underscore in the marker name.
| Tags |
| error |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Stagnation Inlet vs. Free Stream BC for internal flow | liliana | STAR-CCM+ | 2 | August 14, 2024 11:44 |
| Dynamic FSI with SU2 Compressible Solver and SU2 FEM Solver Diverges when restarted | sangeet | SU2 | 7 | August 3, 2022 02:54 |
| Inlet profile in SU2 | Zhen ZHANG | SU2 | 4 | April 17, 2021 11:27 |
| SU2 v6.0: Impose a boundary layer profile at the inlet in parallel | akshaydeshpande | SU2 | 2 | March 19, 2018 10:13 |
| Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 19:42 |
