[Sponsors] | |||||
Jimin.Zhang
Rep Power: 3 ![]() |
Hello everyone, as shown in the attached figure, my case failed during the output stage. Why does SU2 impose a limit that output values must not exceed 10e10?
Jimin.Zhang
Hello, I tried changing the turbulence model in the configuration file from SST to SA, and the run succeeded. I am simulating a Mach 6 flat-plate air rudder flow. I can share my configuration file—I would like to understand why switching the turbulence model to SA made the run successful and whether there might be an issue with my configuration file.
bigfoot
Rep Power: 23 ![]() |
This is a limit in tecplot, not in SU2. The solution is to no export omega to a tecplot file. Maybe later during the simulation, the maximum value of omega will drop and you can write omega as well. SA works because it does not solve for omega.
You can also check the results in paraview, I don't think there are any limits imposed. |
Jimin.Zhang
I see. I've tried changing the output format in Tecplot but haven't experimented with Paraview yet. Thanks for your answer.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Optimization of airfoil Gradient based optimization SU2 | ryupuriwat | SU2 | 0 | March 30, 2023 11:46 |
| SU2 diverging for hypersonic flows | Praveen_krish | SU2 | 1 | January 10, 2023 20:09 |
| SU2 NACA0012 Transitional flow simulation Convergence Issues | morgJ | SU2 | 0 | July 21, 2022 08:42 |
| Rotor67 Simulation in SU2 | kuzuner | SU2 | 6 | March 11, 2021 09:23 |
| SU2 Divergence Problem | Gui_AP | SU2 | 5 | February 21, 2020 12:10 |
