June 19, 2013, 12:30 |
Heat Exchanger Resistance
cfdonline
Assume that there a flat oval tube (thickness T1) of 50 mm width (W1)and 8 mm height (H1)with water flowing at a rate of 2.5 liters/min. Directly below this tube, there a plate (thickness T2) of width of 35 mm (W2). I want to come up with thermal resistance for this assuming there is heat source directly below plate.
Method 1: Direct HT Resistance = r1=(T2/(K2 *A2) +T1/(K1*A1)+ 1/(hA)) Note that here, A2=A1=A=W2*length The remaining portion of oval tube has (behave line fins) a length of S= (W2/2) (top of oval tube) + H2 +(W2-W1)/2 on left side and the same on the right side. Assume that entire plate and tube is adiabatic. Parallel resistance is r2 =1/(Fineff*S*T2). Where Fineff =tanh (m*S)/(m*S) Now we can find equivalent R using 1/R = 1/R1 + 1/R2 Method 2: Area of oval tube At= 2*(W1+H1)*L Total resistance =(T2/(K2 *A2) +T1/(K1*A1)+ 1/(hAt)) Which one is more accurate? Any suggestion or refrerences? Thanks |
June 28, 2013, 07:26 |
#2 | |
i.e. k1/k2 ? Here's a quick answer: make two dimensionless parameters epsilon=k1/k2 and eta characteristic length tube/characteristic length plate, make sure they are << 1. Denote them as epsilon and eta. Now expand both expression you've written in powers of epsilon and eta. The one with the higher order O(epsilon^n), O(eta^n) is the more accurate. |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 04:28 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
