November 18, 2014, 09:49 |
how to put "sphere" in the ".data" ?
wanghuo
Rep Power: 11 |
I want to put the sphere witch is draw in "stl" 5.jpg or draw in the solidworks sphere.png in the ".data" to achieve a certain effect like picture 3.3.jpg ?Thank you very much!
November 18, 2014, 11:53 |
See the other thread for instructions on creating a sphere
I went through the example in the previous thread
Here are the simple steps 1. Create a new layout. 2. Data->Create zone-> Rectangular zone Set the dimensions to 100, 100, 100 Set XMin, XMax to -1, 1 Set YMin, YMax to -1, 1 Set ZMin, ZMax to -1,1 3. Data-> Alter -> Specify Equations use this equation: {Sphere} = x*x + y*y + z*z 4. Create an isosurface of Sphere 5. Data-> Extract -> Isosurface You now have a Sphere in Tecplot. Let me know how it goes |
November 19, 2014, 09:31 |
How to let the sphere and "0.data"in the same layout ?
wanghuo
Rep Power: 11 |
hello Durrell4!
Thank you very much for your help ,I use you method draw a sphere in a layout .I want let the another database “0.data” and the sphere in the same layout :6.jpg,7.jpgBut the result is :8.jpg.Why it is like this? |
November 19, 2014, 09:38 |
wanghuo
Rep Power: 11 |
hello Durrell4!
Thank you very much for your help ,I use you method draw a sphere in a layout .I want let the another database “0.data” and the sphere in the same layout :Attachment 35312,Attachment 35313But the result is :Attachment 35314.The "0.data" is velocity field 9.jpg .Why it is like this? |
November 19, 2014, 11:33 |
Loading data with less variables in to a data set with more
OK we made progress, but we are not quite there yet. If you have a data set with variables like this
x,y,z,Sphere and you load the data with variables x,y,z,u,v,w,Rho,P,T,Cp Tecplot needs to map the variables that you have to the ones you are loading. If you use data alter to create variables to match in the sphere then it will load correctly otherwise load the sphere second and it will load and append the variables. It depends what version of Tecplot you are using. Some of the trouble might be the version you are using does not support the variable mapping. What version of Tecplot are you using? |
November 20, 2014, 04:35 |
wanghuo
Rep Power: 11 |
Thank you Durrell4!The version of Tecplot I am using is "Tecplot 360 2006".Which Version can I use to resolve this problem?
November 26, 2014, 09:57 |
#7 | |
wanghuo
Rep Power: 11 |
Thank you very much for your help! I use the tecplot 360 2013R1.Wen I draw the sphere first ,I load the "0.data".the tecplot prompts “1.jpg2.jpg". If I load the "0.data"first ,and then load the shpere,the tecplot prompts “3.jpg" I don't know that is why ,Could you help resolve it ? I write a letter to you .The "0.data" and the sphere is in the letter. |
free convection around shallow sphere | hamednoordoost@yahoo.com | FLUENT | 12 | April 4, 2013 02:54 |
Experimental data vs SimpleFoam sphere test case : Cd do not match | alsdia | OpenFOAM Verification & Validation | 1 | November 2, 2012 05:37 |
[ICEM] meshing a sphere - large deviation from perfect sphere | murx | ANSYS Meshing & Geometry | 25 | August 15, 2012 12:37 |
CFX analysis of a sphere - drag too low | Rob Findlay | CFX | 6 | March 26, 2007 10:11 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
