March 30, 2015, 15:56 |
Slicing a 3d model
Hassan Iftekhar
Rep Power: 11 |
Hi Every one,
I imported a 3d model .dat file from Fluent in tecplot using fluent data loader. I used sliced function to slice at different planes. Now I want to view these sliced plots in 2D with a scale/ruler/grid on them. How can I do that? Your help is really appreciated. Regards, Hassan |
April 1, 2015, 16:56 |
Jerimiah
Hello hasanifte,
If you extracted the slice into a zone you can then switch to 2D Cartesian view and make sure that the new zone is the only active zone. Then by going to Options > Ruler/Grid, you can turn on a Ruler, or by turning on the Paper you can then see a grid in the background. |
April 1, 2015, 17:30 |
#3 | |
Hassan Iftekhar
Rep Power: 11 |
Could you please guide how to active a particular zone? |
April 1, 2015, 17:31 |
Jerimiah
Go to Data > Extract > Current Slice.
April 1, 2015, 17:52 |
Hassan Iftekhar
Rep Power: 11 |
Current slice option is not available.
I have created two slices usign Extract > Slice from Plane. Now I would like to view extracted slices as 2D. How Can I active particular zones/slice? |
April 1, 2015, 17:56 |
Jerimiah
At this point, you should switch to 2D Cartesian, then open the Zone Style Dialog. On this page turn off all the zones except for the slice you want to view. The Show checkbox controls which zones are visible.
April 5, 2015, 11:58 |
Hassan Iftekhar
Rep Power: 11 |
How can I take derivative of x velocity wrt y?
Whats is the syntax I tried following syntax but it did not work {k} = dd (x velocity)/ddy |
April 6, 2015, 11:21 |
nm
Look up the variable number for x-velocity and use it. Say if it's number 17, I would use V17 instead of x velocity.
tecplot |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 2 | November 18, 2020 10:23 |
problem with solving lagrange reaction cloud | Polli | OpenFOAM Running, Solving & CFD | 0 | April 30, 2014 07:53 |
manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 09:29 |
eddy dissipation model: combustion doesn't occur | roukaia | FLUENT | 0 | December 24, 2011 09:10 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
