Home > Forums > Visualization & Post-Processing Software > Tecplot
Split zone in zones
Old   May 6, 2013, 17:04
Default Split zone in zones
Agustín Villa
agustinvo is on a distinguished road
I have this trouble: I export from Fluent a Tecplot Data file which contains cross-section areas of a duct. The problem is that I've defined the group of sections as an only one zone. Does it exist any form to separate these sections in Tecplot, or I should create these surfaces in Fluent? I can't use iso-surfaces, neither slices. I attach the file and an image.
https://docs.google.com/file/d/0B2XU...it?usp=sharing
agustinvo is offline   Reply With Quote
Old   August 14, 2016, 02:11
malik
afzaal is on a distinguished road
Dear,
Have you found any solution to your problem? Recently i am also facing similar issue and i dont know how to divide a zone into sub zones in tecplot. If you have any solution, please guide me.
Thanks
afzaal is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
