Home > Forums > Visualization & Post-Processing Software > Tecplot
How to plot streamlines on a slice?
Like Tree1Likes
  • 1 Post By Durrell4
Old   February 2, 2014, 17:33
Default How to plot streamlines on a slice?
Bart A.
ziggo is on a distinguished road
How can I plot streamlines on a slice? I only found ways to enable contour or vector plots on a slice.
I've managed to do this in CFD post (see attachment), but because my dataset is too big now CFD post is unable to handle this. Hence I switched to Tecplot 360.
How can I achieve a similar looking visualisation in Tecplot 360? The attachment shows what my goal is. The image shows the streamlines colored by velocity on three different bounded planes.
ziggo is offline   Reply With Quote
Old   February 6, 2014, 16:52
D L
DLuo is on a distinguished road
Streamlines are integrated on U V W vectors so naturally they won't constrain themselves to a slice.
One way to work around this is by forcing one of your Vectors (for example W) to zero. This really only works if you're looking at slices in the principle axis.
If you want streamlines on a Z slice, you can go to calculate variables and create a new variable = 0. Then under Vectors, set X to U, Y to V, and Z to your newly created variable which should be zero.
Now show your slice and seed streamlines on that slice. Because Tecplot now thinks that your Z component of your vector is 0, the streamlines shouldn't deviate out of the plane.
Take caution however, because your Z component is not the true component value, the streamline integration might not be entirely accurate.
DLuo is offline   Reply With Quote
Old   November 17, 2014, 11:45
Scott Rumage
scott_rumage is on a distinguished road
Tecplot has posted a nice tutorial on plotting streamlines, streaklines & particle paths located here: http://www.tecplot.com/blog/2014/10/31/streaklines-streamlines-particle-paths/ .This video should be helpful in answering your question.
Regards,
Scott
scott_rumage is offline   Reply With Quote
Old   November 17, 2014, 11:56
Default Streamlines on a slice
Durrell Rittenberg
Durrell4 is on a distinguished road
Send a message via MSN to Durrell4 Send a message via Yahoo to Durrell4 Send a message via Skype™ to Durrell4
Hi Ziggo,
We have had several requests for streamtraces on a slice in the past few years. Generally the approach Andy outlined is a reasonable approach. There is an alternative method where you extract the slices from the volume domain and use "surface" streamtraces to create the plot of interest. I will post a tutorial on the process using Tecplot 360 EX later today. My tutorial on streaklines etc. is not related to this particular solution, but it gives a simple overview.
Link to tutorial: http://youtu.be/r4wItXyDQb8
Best
Durrell
Tecplot 360 Product Manager
fruitkiwi likes this.
Last edited by Durrell4; November 17, 2014 at 14:54. Reason: added link to tutorial
Durrell4 is offline   Reply With Quote
Old   October 23, 2016, 02:37
amit agrawal
omgcfd is on a distinguished road
sir i am not able to make streamtraces on selected zone..how to creat sir. in figure see i did slice in x axis then i made extract and select my x axis extract and make slice but it not made slice..pls reply
http://file:///I:/untitled.png
omgcfd is offline   Reply With Quote
slice, streamlines, surface, tecplot 360
[General] draw streamlines on the 2D slice hz283 ParaView 4 January 28, 2020 00:33
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 15:40
[OpenFOAM] Paraview: how to plot streamlines and surface mesh together serena ParaView 3 September 9, 2012 22:13
CFD-Post how to plot stress and streamlines? Airone CFX 3 July 9, 2010 11:56
plot streamlines JJ Main CFD Forum 2 December 20, 1999 12:21
