Home > Forums > Visualization & Post-Processing Software > Tecplot
Tecplot visualization OpenFoam data: Unable to load the solution data
Old   June 30, 2017, 01:53
Default Tecplot visualization OpenFoam data: Unable to load the solution data
Nguyen Duy Trong
ndtrong is on a distinguished road
Hi everyone,
It is great appreciation if someone could help me on the following problem.
I am doing visualization the CFD data based on OpenFoam. I converted foam data to Tecplot form using foamToTecplot360 extension in OpenFoam. I got 3 file:
- InterFoam_grid_0.plt
- InterFoam_0.plt
- boundaryMesh_0.plt (in boundaryMesh folder)
My solver is InterFoam then file name is same as solver.
When I open Tecplot and load data using Tecplot data loader it can load my grid file and mesh file in boundaryMesh folder, it can not load solution file (InterFoam_0.plt).
I do not reasons for that, could someone please help me on this problem?
Thanks
ndtrong is offline   Reply With Quote
Old   July 27, 2017, 08:54
Question data interpolation error in tecplot 360ex from openfoam data
narayana vekamulla
vnarayana is on a distinguished road
I have openfoam case file.
for post processing i am using Tecplot 360ex.
1. Tecplot is treating T,U,V,W etc as cell centered where as x,y,z as nodes.
In openfoam there is a conversion called celldata2pointdata by this we can find u,v,w coresponding to x,y,z.
In Tecplot how to calculate U velocity with respect to x,y,z .
i have tried data-> interpolate->linear
the error i got is
" all selected variables of the destination zone must be node located to perform the interpolation . Variable 5 of zone 2 is cell centered[/COLOR]. "
would you please help me. how to get U,V,W velocity coresponding to x,y,z values.
2. I have calculated du,dv,dw using equations in data->specify equations.
how to save this data in excel sheet. Again i need max u, max v, du, dv values corresponding to x,y,z values.
Recently i have installed Tecplot 360Ex.
kindly please help me.
vnarayana is offline   Reply With Quote
Old   July 30, 2017, 12:45
narayana vekamulla
Data interpolation in tecplot from openfoam data
Sent from my Redmi Note 4 using CFD Online Forum mobile app
[Commercial meshers] starccm+ solution data convert into OpenFOAM format akshaybagi OpenFOAM Meshing & Mesh Conversion 1 June 2, 2017 06:09
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 14:50
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
