January 8, 2019, 12:09 |
Video export gives empty file
Rep Power: 9 |
I'm trying to export a video from tecplot, but every time I try it just gives an empty file, with no frames in the video. Tecplot doesn't give any error message, and it appears as if the process worked. I'm using Tecplot 360 EX 2018 R1 on a linux workstation. The data is generated by OpenFOAM and converted to EnSight format. I can manipulate the data as normal in tecplot and everything looks fine, apart from video export. Any help is appreciated |
export, tecplot, video |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
