April 25, 2019, 05:37 |
Particle Pathline: Missing Pressure Gradient Term
Rep Power: 10 |
This is regarding particle pathline calculation procedure mentioned in Tecplot's user manual. https://www.tecplot.com/documentation/
So my question is regarding the procedure adopted there: the first step is to generate streamlines and then mention values for velocity components, mass, radius and drag coefficient. Why pressure values are not being taken as input? Even in the documentation, there is no mention of contribution, in particle's acceleration, by the pressure gradient. Last edited by Pravaah; April 26, 2019 at 06:48. |
April 26, 2019, 20:25 |
Dave Taflin
Rep Power: 8 |
The density of the particles is assumed to be much larger than the density of the fluid, making pressure forces unimportant. See FLUENT's explanation of this here: https://www.sharcnet.ca/Software/Ans...le_motion.html
April 28, 2019, 09:41 |
Rep Power: 10 |
Many thanks for reply
I had one counter question: What you are saying is true for Fluent. What about Tecplot? because there is no mention of any such assumption. Why do they calculate stramlines first? Is it for inital guess of path only? I was thinking if it gets density and velocities then it can easily calculate pressure gradients for those terms. |
pathlines, pressure gradient, user manual |
How to plot a single particle pathline in FLUENT | shashanktiwari619 | FLUENT | 0 | June 24, 2017 00:59 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
particle user routines | Felix | CFX | 1 | July 24, 2006 12:32 |
Particle Injection User Fortran Routine | Adam | CFX | 5 | December 13, 2005 03:16 |
confused about particle user source sub-routine | wayne | CFX | 1 | August 30, 2005 06:55 |
