Home > Forums > Visualization & Post-Processing Software > Tecplot
Rotational data in Tecplot
Old   March 18, 2020, 14:11
Default Rotational data in Tecplot
Nick Thomas
nick.l.thomas is on a distinguished road
I have a CFX simulation with a rotating domain (transient rotor stator) within a rectangular stationary domain. The rotating domain is set as a stationary frame. If I open the .res file in CFX Post, the rotation is already applied to the rotating domain, and using Stn variables I get accurate results (continuous between domains). However, if I open the .res file (or a .trn or .cgns file) in Tecplot the rotation is not automatically applied. No big deal - I can rotate it through the Axial Rotation feature, but my velocity vectors (and Vorticity as a result) are all messed up. Are there any good ways around this? Any file formats I'm not thinking of that would already have the rotation applied in Tecplot? I've tried applying the equation CFX uses for U_stn after I've rotated the data but that hasn't worked either.
EDIT: Found my issue. I needed to change the vector variables to the Stn. Frame quantities prior to rotation so they are the ones transformed (Plot > Vector > Variables). Then it worked as expected.
nick.l.thomas is offline   Reply With Quote
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 02:08
Tecplot visualization OpenFoam data: Unable to load the solution data ndtrong Tecplot 2 July 30, 2017 11:45
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 00:51
[General] NaN color for TecPlot data Eloise ParaView 5 February 15, 2014 14:56
[General] reading tecplot time data in a single file canopus ParaView 0 March 17, 2013 20:12
