How to save the plot setting in the Tecplot? I find every time I import the new cas a
How to save the plot setting in the Tecplot? I find every time I import the new cas and dat, I find the plot setting can not save ,and it should be reset, which takes so much time to do it . Does there have any ways to solve it ?
Save a Layout
Set your settings they way you like them then save a Layout. Then when you want your settings again, you just open the Layout file that was created.
I use layouts for different graphical representations of the same dataset. That way, I don't have to recreate the same object every time or I can start back at a certain part. |
Yes, I know your method,but you know that it is only useful for the same case with d
If your data is similar, same number of zones and variables you can give stylesheets a shot. Stylesheets store just the style of a frame not the entire workspace and can be used in many cases when working across dataset.
We are currently working on improving workflows like you are describing. If you would be interested in a 30 min phone call around this workflow we can give you additional direction and you can describe your workflow in more detail contact support@tecplot.com to setup a phone/video call. |
Could you show me how to use the stylesheet? Yes , I am interested. My phone is 217-
