July 18, 2020, 15:34 |
Load *.xyz file with pyTecplot
Oscar Alvarez
Rep Power: 5 |
I am trying to load a *.xyz file along with it's function file *.fun using pyTecplot.
These load fine using the command prompt and when I just load them using Tecplot. This is what I have Code:
import logging logging.basicConfig(level=logging.DEBUG) import tecplot as tp import sys if '-c' in sys.argv: print("Opening Tecplot") tp.session.connect() tp.new_layout() # Load filename or List of filenames file_names = ["mytest_121000.xyz", "mytest_121000.fun"] tp.data.load_tecplot(file_names) tp.export.save_png('loading_test.png', 600, supersample=3) Code:
tp.data.load_tecplot(file_names) |
August 2, 2020, 18:17 |
I found it!!
Oscar Alvarez
Rep Power: 5 |
The solution was to use
path = "Desktop/AutoCore" grid_file = os.path.join(path, "mytest_121000.xyz") func_file = os.path.join(path, "mytest_121000.fun") dataset = tp.data.load_plot3d(grid_filenames=grid_file, function_filenames=func_file) |
file, load, pytecplot, tecplot, xyz |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
