TecPlot: How to view every 4th grid point of mesh? |
September 24, 2020, 15:39 |
Ronith Stanly
Rep Power: 9 |
Now when I take a 2D slice and then visualize the mesh on it (Slices>Details>Other>Show Mesh), I see a very black slice because of the fine mesh. Can someone tell me how to skip every 4th grid point (or similar) on this slice? I also tried this solution (http://www.tecplottalk.com/forums/viewtopic.php?t=1188) to extract a sub-zone by skipping points, but the extracted sub-zone did not appear in the list of zones, so I could not select it to be visualized. Can someone please help me? Thanks, Ronith |
September 25, 2020, 17:55 |
Rep Power: 12 |
Slices are an extracted surface that will be a FE zone and you can't really skip values with a FE zone.
September 25, 2020, 18:00 |
Ronith Stanly
Rep Power: 9 |
Hi novedevon,
Thanks for your answer. So are you aware of any other way to skip grid points and to visualize it? I am fine even if it is not visualized on a slice. |
mesh, skip points, tecplot |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[Commercial meshers] Mesh conversion from Tecplot format - help | atmcfd | OpenFOAM Meshing & Mesh Conversion | 11 | February 22, 2014 06:34 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
[ICEM] How to demonstrate mesh every 4th point | ringtail | ANSYS Meshing & Geometry | 0 | November 24, 2010 09:58 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
