Home > Forums > Visualization & Post-Processing Software > Tecplot
Unwinding cylinder cut
Old   November 6, 2020, 12:01
Default Unwinding cylinder cut
panasonic18 is on a distinguished road
Hey again,
I am doing a CFD analysis of an axial turbomachine. For that I want to unwind a cylindrical cut through the machine, to analyse the flow around the blades.
I have the outer surface of a cylinder and would like to display it unrolled. I already calculated the cylindrical coordinates based on x,y,z:
r = sqrt(y^2+z^2)
Theta = ATAN(z/y)
If I display this in tecplot, the image is distorted.
Does anyone have a better idea?
panasonic18 is offline   Reply With Quote
Old   November 6, 2020, 18:11
novedevon is on a distinguished road
The best way of doing this is to display an isosurface of theta or R at your desired location. Then extract it, and if necessary switch to R, theta as your axis variables. Or some combination of those steps as required as I'm not 100% clear as to what state your data is currently in.
novedevon is offline   Reply With Quote
Old   November 7, 2020, 15:37
Okay, it worked now. You have to delete the values at the beginning and the end of the cylinder, so plot --> blanking..
But there is my next problem --> Streamtraces
Is there a possibility to visualise these streamtraces on the new surface? By assgning the coorinates to the vector variable it does not work
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
How to implement time-varying boundary conditions in an enclosed cylinder Alejandro-FA OpenFOAM Pre-Processing 0 May 14, 2020 06:29
[ANSYS Meshing] uniform mesh, cylinder with a cut Matiasi ANSYS Meshing & Geometry 5 June 8, 2015 15:08
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Cut a Cylinder and Rotating it. Ledeeb FLUENT 0 February 18, 2015 08:38
