Home > Forums > Visualization & Post-Processing Software > Tecplot
highlighting a region of the y-axis or x-axis
Old   August 6, 2021, 20:57
Default highlighting a region of the y-axis or x-axis
Islam Abdelghafar
Islam Abdelghafar is on a distinguished road
Hello everyone,
I have a question about how to highlighting a region of the y-axis or x-axis with a specific color in Tecplot like the figure below.
Best regards,
Islam
Islam Abdelghafar is offline   Reply With Quote
Old   August 10, 2021, 13:15
Scott Fowler
wsfowler is on a distinguished road
Tecplot 360/Focus doesn't have an "axis highlight" option built-in. But you could achieve the effect by using a Rectangle geometry.
From the Insert menu select Rectangle. This will change the mouse tool and you can draw a rectangular geometry in the region of interest. Double-click on the rectangle and you can change the following settings:
Draw Order: Before Data
Coordinate System: Grid
Then you can type in exact X,Y,Width,Height values to make sure it's in the correct spot.
I hope that helps.
Scott
wsfowler is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
alphat Wien3 OpenFOAM Running, Solving & CFD 22 August 15, 2019 10:00
What exactly the Relaxation factor does? Raza Javed OpenFOAM Running, Solving & CFD 11 July 2, 2019 03:42
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Taking too much for run Grimoli OpenFOAM Running, Solving & CFD 5 November 26, 2013 20:07
