Home > Forums > Visualization & Post-Processing Software > Tecplot
Showing axis on the opposite edge.
Old   May 16, 2022, 02:52
Default Showing axis on the opposite edge.
Shahid Khan
shahidkhan is on a distinguished road
I have the results of a simulation which I want to compare with a reference paper. I want my plots to look as close as possible to reference. (Not the data but plotting). For that, I want to show the Y-axis on the edge as shown in the reference. When I am trying to tick on show on the opposite edge the ticks and labels are coming inside the domain and the plots don't look nice (Y-axis not visible).
Can anyone help me in solving this issue? It will be very helpful to me.
Another issue- How can I convert units from 'm' to 'mm' in my plot as shown in reference?
I am attaching figures for refeernce. One of them is of reference paper and the other shows the issue I am facing.
Note- I am showing my plot using translucency so that you can understand what is the issue
File Type: jpg my_result_y_axis_hidden_behind_flow_domain.JPG (31.0 KB, 7 views)
shahidkhan is offline   Reply With Quote
Old   May 26, 2022, 23:43
ddomz is on a distinguished road
To convert your units to mm go to Data -> Alter -> Specify Equations.
You'll have to create a new variable that is equal to the old one multiplied by 1000. For example, the formatting for x would be:
{x_mm} = {x) * 1000
Then change your plot to have the new variable on the axes.
I'm not sure how to fix the graphic issue. Maybe it has something to do with the range of your data?
ddomz is offline   Reply With Quote
Old   May 27, 2022, 19:22
Brandon M
Brandon_CFD is on a distinguished road
Hello Shahid, could you share your plot with support@tecplot.com? They could take a look at it and give you some more information on the issue you are facing in plotting the y-axis.
Best,
Brandon
Brandon_CFD is offline   Reply With Quote
[snappyHexMesh] SHM not snapping to edge features after adding layers stefano.garbin OpenFOAM Meshing & Mesh Conversion 1 March 10, 2022 04:17
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
[ICEM] Skewed elements on straight edge in one ogrid block balrog_f ANSYS Meshing & Geometry 3 September 21, 2018 10:40
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
