Home > Forums > Visualization & Post-Processing Software > Tecplot
Visualizing Velocity Vectors in 2D Plane from Quiver Data
Old   June 22, 2022, 17:38
Default Visualizing Velocity Vectors in 2D Plane from Quiver Data
Ruby
rd08 is on a distinguished road
For background: I am using videos to determine smoke flow through a nozzle and using Matlab command 'opticFlow' to get the Vx and Vy components of the velocity vectors. I had initially used the 'Quiver' function to get the most accurate image of vectors however I was not able to export the actual quiver data of (u,v,x,y) so had to use the Vx and Vy components individually.
Now, I have the experimental data from Matlab where I have the x-component and y-component of my velocity vector, Vx and Vy, respectively. This is then put into excel and imported into Tecplot (using the add-in). My problem is that Tecplot plots each component in a separate zone, thus just plotting the data 1 on top of the other and not together into 1 velocity plot.
Is there any way to plot both Vx and Vy into the same sheet to get 1 velocity plot? They both have the same x and y positions so my variables would be (x, y, Vx, and Vy).
Any help would be appreciated. Thanks.
rd08 is offline   Reply With Quote
Old   June 26, 2022, 23:04
Scott Fowler
wsfowler is on a distinguished road
It sounds like you may want to create a 2D contour plot showing your velocities? Or a 2D vector plot?
If so, you may need to use the Tecplot add-in as explained in this video: https://youtu.be/gmHHgIYGWyU?t=75s
If you're still having trouble getting your data in, reach out to support@tecplot.com.
wsfowler is offline   Reply With Quote
Filtering Velocity Vectors + Creating meridian planes L4M496 FLUENT 0 December 28, 2020 09:15
Mapping velocity data to a boundary cyln OpenFOAM Running, Solving & CFD 1 July 22, 2017 16:13
[CFD-Post] Using data from inserting a plane siw CFX 1 September 8, 2010 08:57
Velocity vectors SA Main CFD Forum 1 March 8, 2007 02:04
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
