Home > Forums > Visualization & Post-Processing Software > Tecplot
"NoData" values for Tecplot .dat files
Old   August 25, 2022, 23:38
Default "NoData" values for Tecplot .dat files
Z
watisaCFD is on a distinguished road
Probably this is a silly question, but I can't happen to find any information or documentation about this anywhere.
Simply put: How can someone define an "empty" value in Tecplot (e.g., a NaN, NA or Null) for a variable in the .dat input file or elsewhere?
The reason why I need to do this, is because I have a large output generated from another routine, where certain variables have "gaps" because of how the data behaviors, and I need to interpolate them into another geometry while trying to maintain where these gaps are.
My original idea was to simply import the whole data and a defined XYZ region in Tecplot and use the interpolate function, however, if I try to use any common namesake for the "NoData" fields, Tecplot won't accept the input. Another workaround I tried was to set an extreme value (i.e., -9999) as a NoData field, but when performing the interpolation, the -9999 value pollutes the interpolated data.
Is there a way properly define an keep a "NoData" record in Tecplot, or should I simply use another tool/method to solve this issue? If so, may anyone give me a recommendation?
Thanks in advance
watisaCFD is offline   Reply With Quote
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
a question of open ".cas" and ".dat" files fanzhong Meng FLUENT 4 May 15, 2006 12:40
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
Y* and really large .dat files Simon Blakey FLUENT 3 August 8, 2003 10:34
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
