March 22, 2023, 15:14 |
histogram file not opened by tecplot
West Midlands
Rep Power: 3 |
I am trying to open a histogram file using tecplot, however when i try to open it it gives error, what could be the reason.
Error occurred on line 2 near position marked with @ below: ZONES I= 16J@= 16K= 7 DATAPACKING=POINT |
March 28, 2023, 12:40 |
Scott Fowler
Rep Power: 16 |
That indicates that the Tecplot ASCII format is incorrect. It appears that you may need to add spaces and "ZONES" should be "ZONE":
ZONE I= 16 J= 16 K= 7 DATAPACKING=POINT What application wrote this file? It seems that the application may have to be updated to export Tecplot ASCII files correctly. See the Data Format Guide here: https://www.tecplot.com/products/tecplot-360/#docs If you're still having problems, I'd suggest contacting our support staff. Scott |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
