Home > Forums > Visualization & Post-Processing Software > Tecplot
Label points on 3D surfaces
Old   January 22, 2025, 14:43
Default Label points on 3D surfaces
Kate
kclements is on a distinguished road
I'd like to be able to show the values of a variable at specific coordinates of my surface solution (3D Cartesian plot) in Tecplot 360. I know how to Probe and Probe At, but is there a way to show the values as labels pointing to the specific point on the surface it corresponds to? Similar to the Plot -> Label Points and Cells option but at specific points rather than every ith node/cell.
Thanks.
kclements is offline   Reply With Quote
Old   January 23, 2025, 10:18
gibson
GibsonA is on a distinguished road
Hi Kate,
The fastest, easiest way is to navigate to Plot > Label Points and Cells > Show Node Labels (or Show Cell Labels if that's closer to the values you want) > and change this to "show variable value" rather than "show node labels". Then choose the variable of interest.
If you want more specific values, you can try probing, then using text boxes to display the info. If this isn't exactly what you want, send an email to support@tecplot.com and I can look further into it. Cheers.
GibsonA is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 09:43
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
error while running simpleFoam BakedAlmonds OpenFOAM Running, Solving & CFD 9 July 14, 2016 06:37
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
