Home > Forums > Visualization & Post-Processing Software > Tecplot
Pressure coefficient plot Tecplot
Old   May 17, 2025, 21:50
Default Pressure coefficient plot Tecplot
Lisa
CFD_Newbie_248 is on a distinguished road
Hi there,
I wish to plot pressure coefficient against x/chord in tecplot 360 for common research model high-lift. This plot should be for the slat, wing and flap.
I took a slice which includes slat and flap but it does not look correct. Can anyone show me an example please
Many thanks
CFD_Newbie_248 is offline   Reply With Quote
Old   May 19, 2025, 11:35
gibson
GibsonA is on a distinguished road
Hi there,
It sounds like you want the pressure coefficient along the boundary of the wing, for all sections of a wing chord. This is a common goal with Tecplot 360. Here is one of our video guides doing exactly that https://tecplot.com/2022/02/25/extra...-xy-line-data/ with the Onera Wing dataset which is included with 360 installs.
If you have a few more questions or find your workflow needs to be changed from this, you can reach out to Tecplot support at support@tecplot.com. Hope this helps, cheers.
GibsonA is offline   Reply With Quote
pressre distribution, tecplot360, wing surface
Calculating Stagnation Pressure Coefficient dwaw FLUENT 0 March 21, 2025 09:43
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
How to plot pressure coefficient in CFX and how to export it to tecplot aja1345 CFX 1 May 28, 2016 07:00
How can I plot the pressure coefficient vs angle? ck3 FLUENT 4 February 4, 2016 07:01
