Home > Forums > Visualization & Post-Processing Software > Tecplot
How to plot Lift and Drag Coefficients using tecplot 360
Old   October 7, 2011, 06:14
Default How to plot Lift and Drag Coefficients using tecplot 360
Rui Vizinho de Oliveira
RuiVO is on a distinguished road
Hello, I can calculate the integral values of forces and momentums over an airfoil surface but I can't obtain a plot from it. In the x variable option I can't select x coordinate. Instead the index "i" is selected and I don't see any curves.
Best Regards
Rui
RuiVO is offline   Reply With Quote
Old   October 19, 2011, 09:09
FlowLy
giuli@ is on a distinguished road
Hi Rui,
which solver are you using?
giuli@ is offline   Reply With Quote
Old   October 19, 2011, 09:13
Hi giuli@, I'm using the simpleFoam solver, for incompressible steady flow over an airfoil.
Best regards
Rui
Old   October 20, 2011, 09:21
FlowLy
I'm not really into OF;
what I remember about plotting Cl in Tecplot360 with Fluent data is that I had to extract the variables I wanted in Fluent itself (saved in .xy files), and than import these and make xy plots in Tecplot.
Try to find the way of telling openfoam to get the Cl, Cd along the desired section for all the X values (what I was doing in Fluent),
Then, make a ".dat" file with this header:
VARIABLES="x","Cl","Cd"
and under, in columns, the corresponding values extracted.
Sorry but it's all I can think now :-/
Old   April 13, 2012, 06:13
FlowLy
Errata corrige: I was plotting velocities components (it doesn't make sense to plot Cl and Cd along x since these are integral values)
Old   April 13, 2012, 14:17
Scott Rumage
scott_rumage is on a distinguished road
Rui,
You might review this tip on the Tecplot web site to see if it helps you with your question: http://www.tecplot.com/Training/Plot...dyResults.aspx
Regards,
Scott
scott_rumage is offline   Reply With Quote
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
how to set lift and drag coefficients in force mon alagesanj FLUENT 0 November 16, 2008 20:47
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 14:05
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 14:45
pressure. lift and drag coefficients waqar mahboob Main CFD Forum 0 July 25, 1998 03:34
