Home > Forums > Special Topics > Visualization & Post-Processing
extract data from axisymmetric flow
Old   January 15, 2019, 12:48
Default extract data from axisymmetric flow
fan li is on a distinguished road
Hi everyone
I have done an axisymmetric flow in Fluent with the geometry at the order of magnitude of 10e-9 m. Now I want to rotate the flow field to get 3-D results (cylindrical coordinate to cartesian coordinate)and then interpolate it as I do not need that many grids.
I have tried to use CFD-post, it can not show and export the results correctly due to the nano-geometry I am using, although it can rotate the flow field along axis.
I also tried the "Data-Alter-axial roation" in tecplot 360 2017 version, the problem is that tecplot does not show the 3D view after rotation which disables me to define the region where I want to do the interpolation.
I finally export the data from fluent to matlab and do the rotation and the interpolation, but the interpolated results near the boundary are not very accurate due to the built-in interpolation method in matlab.
Any suggestions to do the rotation and interpolation.
Thanks a lot!
Fan
fan li is offline   Reply With Quote
an axisymmetric flow, coordinate transition
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 00:51
Combing surface data with flow measurement data tec Tecplot 3 October 9, 2014 11:50
How to extract data of specific variable from PHI and Q1 file? mukut Phoenics 3 October 17, 2011 06:13
information from saved data files:Unsteady flow Atul FLUENT 5 July 27, 2008 20:05
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 03:03
