Problem: Cannot get Results to work in post processing |
August 5, 2019, 10:50 |
CT
Rep Power: 6 |
Hello CFD Community, this is my first post and I am currently working in ANSYS Fluent.
I am currently working on modeling flow through a butterfly valve when it is open/closed and at a few other angles. I have gotten the closed version to work and now I am trying to get the open version to work using the same model (Laminar flow, 1-inlet/1-outlet, same flow velocity, same solving methods). However, after multiple attempts I keep getting results that are inf (look at picture below titled 'contour prob'). My continuity is going off the charts so I assumed to change my mesh and make it a higher density, but to no avail. I have tried multiple meshing attempts all different so I am not sure if this is the problem anymore. Could anyone provide insight onto what may be causing this? Like I said the closed version worked and now all I did was turn the valve to be open in SpaceClaim. TO SEE THE PICS I POSTED PLEASE CLICK ON THIS LINK TO THE STUDENT COMMUNITY ANSYS FORUM: https://studentcommunity.ansys.com/t...ostbadges=true Below I will post a pic of the mesh as well, keep in mind this is just one of MANY meshes I have tried. Last edited by mattsarg55; August 5, 2019 at 10:53. Reason: include pics |
ansys |
[snappyHexMesh] Problem in results with snappyHexMesh between refinement levels | Phil_WO | OpenFOAM Meshing & Mesh Conversion | 2 | November 8, 2018 03:49 |
[OpenFOAM] getting problem in post processing | sai.patil | ParaView | 1 | November 1, 2013 18:32 |
[OpenFOAM] Post processing problem in Xfce desktop environment using paraFoam | tariq | ParaView | 4 | July 8, 2013 10:09 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 12:44 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
