-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] How to mesh an airfoil? (http://www.cfd-online.com/Forums/ansys-meshing/105705-how-mesh-airfoil.html)
Julian121 August 7, 2012 05:30
4 Attachment(s)
I am trying to mesh a 3D airfoil using edge sizing and inflation functions in ANSYS.
I have used quad mesh instead of triangular to mesh the airfoil.
I am not sure if the mesh is 100% correct.
Could you please tell me if there is any problem?
Please look at the screenshots.
Thank you in advance!
flotus1 August 7, 2012 06:15
the volume jump between the last cell of the prism layers and the first cell of the regular mesh is far too high.
Why wouldn't you use a block-strucutred hexahedral mesh for this purpose?
Julian121 August 7, 2012 07:40
1 Attachment(s)
I have never used hexahedral mesh before. I don't know how to do it.
I have changed the mesh and used triangular mesh. How is that now? Is it acceptable?
flotus1 August 7, 2012 08:00
Looks better, but still the transition between the cell volumes looks too fast.
Don't forget to include the prism layers.
I don't think that you need such a high mesh density at the leading and trailing edge of the airfoil.
Personally, I would avoid tet meshes and use hexahedrons whenever possible.
I think there are some tutorials in this forum about this topic, some of them especially dealing with airfoils
Touré August 7, 2012 08:59
It' better to have prism on the boundary layer (airfoil). You can keep the triangles at the same time.
Check at http://www.cfd-online.com/Forums/ans...nt-places.html
Julian121 August 7, 2012 09:15
Do you mean inflation? As I am using sweep method, ANSYS does not allow to create inflation for 3D Airfoil on the boundaries.
cfd seeker August 7, 2012 09:45
http://www.youtube.com/watch?v=tYrbScUH9RE
http://www.youtube.com/watch?v=EknKVAJGEJ8
http://www.youtube.com/watch?v=6wQPeBpvwCk
here are the video tutorials for strctured hexa meshing on aerofoil...hope it helps have fun
flotus1 August 7, 2012 10:12
I see no point in sweeping a tet mesh.
The tutorials brought up by cfd seeker should render this discussion pointless. Use ICEM if you want to create reliable results on a high quality mesh.
Julian121 August 8, 2012 13:53
Could you tell me how I can reduce the transition speed between cells in ANSYS meshing? I am not familiar with ICEM.
flotus1 August 8, 2012 16:47
I think there is an option called "transition" or "growth factor" in hidden in the settings. I really don't know exactly.
But I can tell you: The time spent learning ICEM is well-wasted.
It is even the faster way to achieve a reasonable mesh quality in this case.
With the tutorials posted here, you will be done in only a few hours.
Julian121 August 8, 2012 19:17
1 Attachment(s)
Thank you Alex. I found that option. How is the mesh now?
flotus1 August 9, 2012 02:49
It still hurts my eyes ;)
But I guess if you are committed to the Ansys Mesher, this is the best you will get.
This still holds true.
gus.gkikas March 28, 2013 09:05
Hello!
I have a few question on this subject!
I am working on a project,pretty much the same as Julian121,and i have a problem with meshing on airfoil too.
I want to ask,if I can mesh a boundary geometry (including the airfoil shape) with ICEM,and if the export file of the ICEM can import in Ansys mesher,in order to continue the project on the workbench.
Thanks!
I am waiting for your responses! :)
