How to generate unstructure mesh of this geometry?
1 Attachment(s)
Hi Everyone, I would like to generate hybrid mesh using ICEM. The structure mesh will be genrated in the building, which has been cut off from the geometry in attachment. Then I would like to generate the unstructure mesh in this geometry in ICEM. I have never use ICEM to generate unstructure mesh. I tried many times but it still not succeed. Thank you for the help in advance.
Li |
would you mind having a look at the link in my signature, it's a small introductory guide in ICEM
Hi Li
I am using GridPro. It can create good quality mesh even in small regions. I can help you with this case if i get the geometry. Can you post the geometry in IGES or STL format? |
the tin file does not work, can you share the hole project ?
1 Attachment(s)
Here is the project files. Thank you. |
Li |
