Parameterizing BladeGen Curves
Dear all
Here i m trying to prametrize the blade curves generated in BLADEGEN 12.0 to be used in an optimization process, same as the way done in mechanical designs and etc. but i cant figure out how to do it? what parameters should i define and how ? Regards |
did you manage to do that? I'm encountering the same problems (I have to change the Bezier control points of the profile curves, at each span station) Yours sincerely, Claudio |
good luck with that. |
Where you able to do that? I am also stuck . What are other options
For *.bgd model do "File > Export > Batch Input File", save it as *.bgi file. These is well reaaeble text file with all parameters.
