Axial compressor calculation steps?
Dear All. I'm a newbie in CFX calculations and i need your advices concerning calculation of axial compressor stage in CFX.
I calculated axial turbine before and everything was OK. But in compressor (Stage 37), when i set the same boundary conditions (P_total_in, T_total_in and P_static_out) the flow goes in wrong direction. Solver puts wall on 100% of inlet. The only way i managed to calculate it right is by setting of "supersonic" in outlet conditions. Could you please tell me what i'm doing wrong and what are the right steps of compressor calculation should be? TIA, Oleg. |
rpm is 17188.7 or -17188.7?
-17188.7 rpm
whats inlet and outlet pressure? and flow direction (-1 axial, 0 for other directions)?
Inlet total pressure 101.4 kPa, outlet static pressure = 138 kPa. I'm not sure what you mean on "flow direction". The flow goes in reverse direction comparing to how it shoud be (from outlet to inlet)
are you using rotor or complete stage. If rotor then 138 KPa is very high value, beyond the stall point!! Even with stator case, it is still too high value, have start with 101325 Pa and gradually increase in increment of 5000
really, i'm not sure that i'm doing as i suppose to do for compressor.
dear Far. Maybe there's some specific BC or loss model need to be set for compressor calculation? Is the task formulation that i use right and compressor should calculate OK with such scope boundary conditions an the probles is just in me? |
Thanks for the advise. While increasing pressure on 5000 Pa what should i control as convergense parameter? Mass flow or maybe something else? in other words when should i decide that I can inrease pressure? |
Simple. Just use 101325 pa as inlet pressure (or profile at later stages) and outlet pressure 101325, then gradually increase static pressure at outlet to
105000 110000 115000 120000 122500 125000 127000 128000 129000 |
I understood about increasing outlet pressure step by step. But what parameter should i control to decide that it is the right time to increase pressure? e.g. i'm doing calculation for P_stat_out=101325, controlling what parameter i can decide that it's time for increasing presure up to 105000? Mass flow rate stabilize? or maybe some of convergense parameters go lower than some specific value?
If the inlet pressure is about 101kPa and the outlet pressure is about 130kPa then you should be using a reference pressure of 101kPa and an inlet pressure of 0kPa, outlet of 29kPa. If you do not use a reference pressure you will have more round-off error and that can lead to convergence problems.
Are you using a reference pressure? |
Thank you for advice. |
Dear ghorrocks.
I have a question concerning total pressure ratio. Can i plot total pressure at stage oultet while solver running the calculation in new monitor? |
Could you please post some pics of your domain and mesh. Also post information about total no of nodes in domain, any information about the interface between rotor and stator.
Any how, compressor flows are more difficult to handle than the turbine and you need to handle it by putting little load at start-up (in terms of rpm and pressure at outlet) and then ramp-up to desired value. Also search the forum for older posts regarding the same issue |
Thanks Far!
1 Attachment(s)
This should also be noted as the no. of nodes increases compressor simulation tend to numerically stall at the higher pressure ratio than for coarse mesh. Therefore it is good idea to refine mesh further and also check the solution at lower back pressure for the current mesh.
Moreover which turbulence model you are using? What is Y+ in domain? Since appropriate Y+ should be used for each model. Other things to be checked are (important to solution convergence and accuracy): aspect ratio, max and min angle, expansion rate |
+--------------------------------------------------------------------+ | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio | +----------------------+---------------+--------------+--------------+ | | Minimum [deg] | Maximum | Maximum | +----------------------+---------------+--------------+--------------+ | Rotor | 41.5 ok | 6 ok | 736 ok | | Stage in | 85.7 OK | 1 OK | 7 OK | | Stator | 46.0 ok | 40 ! | 52 OK | | Global | 41.5 ok | 40 ! | 736 ok | +----------------------+---------------+--------------+--------------+ | | %! %ok %OK | %! %ok %OK | %! %ok %OK | +----------------------+---------------+--------------+--------------+ | Rotor | 0 <1 100 | 0 <1 100 | 0 2 98 | | Stage in | 0 0 100 | 0 0 100 | 0 0 100 | | Stator | 0 <1 100 | <1 1 99 | 0 0 100 | | Global | 0 <1 100 | <1 <1 100 | 0 1 99 | +----------------------+---------------+--------------+--------------+ |
Use K-epsilon (also use lower pressure at outlet as discussed earlier)
