fluent autosave?
Hi
I'm running Fluent through workbench. If I run a simulation for 100 iterations and save before I close fluent and then open fluent again, then the calculations are not saved. Even though I click save project before I close fluent, it only saves the setup and not the iterations that I carried out before I closed fluent last time.. Anybody who knows how to make it save properly, so I can do further iterations when I open up fluent? Thanks |
You only save the case file, but you need to save the results, too. I don't know if you can reload the last state automatically, but you can autosave the data every x-iterations. When restarting, click on file->import->data. Good luck. |
