Large Eddy
My Large eddy simulation doesn't work. What are the main calibration for the initialisation of the measurement.
Re: Large Eddy
Dear Gernot:
Specificly, what is the error. What did you mean from "DOESN'T WORK". Please calrify your problem. Best Regards Mehdi Ghoddosy |
Re: Large Eddy
yea ok
point 1: What's the difference between the Subgrid-Scale Models Smagorinsky-Lilly and RNG (Define -> Models -> Viscous) point 2: What means the statement Reversed flow in 6 faces on pressure-outlet 10. and point 3: Error: divergence detected in AMG solver: pressure correction Error Object: () Which pressure-alignment I had to change? Thank you very much for helping me! Cheers Gernot |
Re: Large Eddy
Smagorinsky-Lilly is a Subgrid Scale Model of LES, RNG is not but an option of the Standard Kappa-Epsilon model.
For information on Subgrid Scale Models look on http://www.fluentusers.com/fluent/do...ug/node454.htm point 2: whenever FLUENT reports 'reversed flow', it simply means that when it concerns a boundary that is set up as an outflow, the solution of the flow leads to flow entering the domain instead of leaving it. And vice versa for a boundary that is set up as an inflow. point 3: is for somebody else to answer. |
