boundary conditions of level set equation
Hello
I am starting to write a simple code with level set method by constant external speed. but I do not know, what boundary condition shuold I use? thanks |
Re: boundary conditions of level set equation
Simple interpolation --> Constant interpolation or linear interpolation. See Fedkiw's papers.
Which Fedkiw's paper does explain these boundary conditions?
How can I use simple or constant interpolation for boundary conditions of level set equation? what about periodic or extrapolating boundary condition? thanks. |
The title begins with "non-oscillatroy ...". Need to google.
I red this paper, but I donot know, what boundary condition can I use for edges of my computational grids? this paper has used ghost fluid method for zero level set funtion, not for edges of computational grids. what can I do?
thanks |
Is your problem solved?
I am also using level set evolution to track moving interfaces. I am using one sided higher order differences to discretise derivative of \phi. Though, I am able to capture the interface at later times but there are garbage values at boundaries. Could anybody suggest how to discretise the gradient of \phi at the boundaries. Thanks |
BC for LS
The boundary condition is a Dirichlet BC at the inlets where the value of the LS is to be constant. That should solve the problem.
Dont remember the exact paper where its written. |
A Review of Level-Set Methods and Some Recent Applications
Cheers |
