Boundary condition in a multiphase flow
Hi to all,
I have a problem in the setting of the boundary condition of a multiphase flow using interfoam. My case is summarized as follow: at the initial time t=0 the right wall of a closed tube completely filled with a liquid is removed, allowing the liquid to exit the domain and, at the same time, allowing the gas to enter. I set this boundary condition: U) fixedValue (0,0,0) in the pipe wall and in the left inlet, zeroGradient in the outlet p) zeroGradient in the pipe wall and in the left inlet, fixedValue of 1 atm in the outlet alpha) zeroGradient in the pipe wall. For the left inlet and the outlet I tried some case: - InletOutlet/InletOutlet - zeroGradient/zeroGradient - zeroGradient/InletOutlet - zeroGradient/calculated but all this case give me strange solution Someone have an idea to set the boundary condition for this case? thank to all |
