lagrange solver
Hi all,
I have a question to you all due to the lagrange solver. My new Project is a hydrocyclone with particel Simulation. Last year I simulated a hydrocyclone (just flow field) and now I have a new cyclone design and want to simulate the flow field and particel tracking in the cyclone. First question - Particels are nonreacting, so is it possible to create the flow field first ( simpleFoam ) and after it using icoUncoupledParcelsFoam for the particel tracking ? Second question - Is there any hints of the complex particel Settings that I have to make in the propertie file or do I have to check out the code for resolving the variables like SOI ... etc. Furthermore I think it is possible to inject a cloud of particels with different Diameters. Third question - If I use icoUncoupledKinematicParcelFoam the particels are not only moving on the streamlines, aren īt they? Fourth question - at the beginning I want to inject some particels into the 2D pitzDaily tutorial. Therefor I solved the flow field with simpleFoam and injected particels with the icoUncoupledKinematicParcelFoam. The Output of the solver seems okay and particels are injected but I can not see any particel with apraview. The lagrangian field is loaded but there are no particesl? Thanks in advance and some good hints. Tobi |
Hi Tobi,
I'm sorry I don't have responses for your questions but I think you have the answer I am looking for ^^ Please could you tell me how did you to combine simpleFoam and icoUncoupledKinematicParcelFoam ? I need to modelize water droplets in gas, I have already created the gas flow with simpleFoam but I don't know how to inject it in "icoUncoupled[...]Foam", I would like to edit the existing tutorial hopperInitialState but I am really lost as I am a new OpenFoam user. Thanks in advance for your response |
Hey Tobi,
It's been a while since your post, but I am currently working on the same problem. With your experience, can you now answer your questions from the post? Thanks for your Info Cheers |
Hi
have you found a solution to your problem yet? I converted everything to IcoUncoupled but don't get Lagrange fields and don't know why. If you have results, could you upload your files? Regards Johanning Quote:
