Importing Geometry Issue
1 Attachment(s)
In the picture bellow you can see the model I have imported into ANSYS workbench 18.1. Only one of the segments are imported as a solid, the rest are surfaces. I believe this is messing up the mesh. Has anyone got any ideas on how to import the segments as solids? Also, I have made numerous changes to the model and imported it into ansys and the segments seem to swap around as to which ones are surfaces which ones are solids.
All input is appreciated, thanks |
before clicking generate you will see option in DM (design modeler)- something along lines upload solids, surfaces, lines
un check surfaces and lines and leave only solids.t then you can go back to space claim that should help you. |
